Roberts210
Anybody here use SpeedBleeders? I've used them for many years on all my vehicles. Love 'em.
http://www.speedbleeder.com/
They always leak on me. The fluid takes the path of least resistance and in my experience, that path was out through the bleeder threads instead of going up against check valve spring pressure.
I had a truck that had really loose bleeder threads on one wheel. I tried a new screw but it was the casting. I was pedal bleeding into a fluid filled bottle and the air just leaked back in. I wrapped the screw with a little teflon tape and got the job done. When you close the bleeder the seal is at the bottom of the screw and the tape caused no problem.They always leak on me. The fluid takes the path of least resistance and in my experience, that path was out through the bleeder threads instead of going up against check valve spring pressure.
When I did my old truck sealant coated screws hadn't been invented yet ha ha I got the Motive after readung a lot of reviews and it is that thread problem is why I don't like the vacuum method.They come with sealant already on the threads, but in my experience, the sealant washes off when the fluid goes passed the threads. I haven't tried Teflon tape. I think what I'm going to do next time is get a Motive bleeder.
I had them many years ago. The thread leaks plus their eventual failing from what I assumed was Minnesota road salt made me go back to the 'wife presses on the pedal as I open and close the bleeder' method.
