I'm interested. Depending on how big it is? Maybe you could take a pic with a tape measure next to it? Or if possible, could you give me its dimensions,thanks
And what is the tool shown in the bottom? Is it like a punch for different size bearing caps? Are there two different sizes on each end for a total of 4 different sized bearing cap strikers? I believe this is basically a tool for replacing u-joints/cross and bearing kits in the "field" where you might not have a vise handy. Set the speedee on the ground lay the problem u-joints yoke on top so one set of bearing caps are positioned vertically and aligned/centered over the round groove in the speedee. This speedee just provides a convenient support for the u-joint, then you drive the caps down and out (maybe with the shown tool?)
