Hi!
Would anyone happen to own a 5hp , 80 Gal. Speedway Compressor? If you have this model could you please show me a pic of the wiring under the capacitor/junction box located on top of the motor itself? I have one of these and cant remember where the run/start capacitors are wired to? there is a small terminal block that has Line, Yel, Black, Red on it and the other side has
Neutral, Black, red, yel. One of the capacitors was wired to Line/red/black and Yellow. Any photo would be of great assistance! Thanks so much! Here is a photo of my block as it sits on top of the motor itself.
HELP!! Where are the start and run capacitors wired to on this terminal block atop a 1Ph, 240V Cap Start/Run motor? I know one was wired to the black line and Yellow but not sure if it was a start/run cap? Need help knowing where and which cap get wired into circuit
