SPGX/Nohr-S vs Ghostshield vs RustBullet/Hellfire on ground concrete
Atlanta, GA
Hi everyone,
I'm looking into putting down one of the polyaspartic coatings this winter. I’ve spent a few days reading about the different flooring options on allgaragefloors.com and on the forums here, have a few questions and would like to get some recommendations too.
It’s a 440sqft previously painted concrete floor that is otherwise unsealed. There are 3-4 longer (5ft+) but thin and shallow cracks that I will be repairing. A drop of water on bare concrete where the paint has lifted off sinks right in in about 10 seconds. My plan is to grind it down to get a good bonding surface, repair the cracks, and then go one of these ways:
1) polyaspartic/polyurea coating i.e. SPGX/Nohr-S
2) densifier and sealer i.e. Ghostshield
3) RustBullet/HellFire
I am not considering traditional two part epoxy + polyurethane top coat due to the extended time out of service and cooler temperatures for this time of year.
This will be a DIY installation with 1-2 helpers. Short application time, short return to service time, and the ability to get a good coating in cooler temperatures (30-60 degrees here in Atlanta, GA) are important as I would like to get this done quickly. It is for a residential garage that currently sees moderate DIY usage with spilled automotive fluids, cars being pulled in and out, floor jack and jack stands, heavy toolboxes and cabinets, some occasional carpentry, but no welding. This is for my parent’s garage, and I’m really hoping to be able to give them a floor that will be able to stand up to my moderate DIY use and then continue to look good for them for a long time after I move out in a few years. Good UV stability is important since there are multiple windows and the garage doors spend a lot of time open.
My concerns:
1) polyaspartics: Of particular concern to me is the impact resistance of the polyaspartic coatings. I’ve seen a few threads where people complained of chipping after dropping blunt items i.e. sockets. I’m also wondering about the ability of polyaspartics to hide the currently present cracks in the floor after I repair them.
2) densifier and sealer: I like this option because I can do the driveway with the same products, but I’m pretty sure this will do nothing for the cracks already present in the floor. I'm also not sure if the cracks will even bother me after they are repaired... would love some feedback from anyone who has used Ghostshield on an older (namely, cracked) floor.
3) RustBullet/Hellfire is a big question mark to me. The specs look great, but I don't know how the durability compares. It seems more like it was meant for less prep, but I'll have to get the previous paint off anyway, so I'm thinking I might as well grind and use something else. Which is a pretty poor reason to NOT use one of these, so I'm definitely open to recommendations here.
So, in short, are people still experiencing chipping with the polyaspartics? Also, do polyaspartics require a primer if the concrete is prepped by grinding?
Please let me know there are other options I haven’t considered. I'm trying to capitalize on my own labor here, hence the lack of references to porcelain tile (never done it before) or interlocking tiles (expensive).
Thanks in advance! This forum has been a huge help to me over the last year since I found it.
LegacyIndustrial
deerfield, IL
Mom & Dad would probably enjoy the decorative good looks of our Nohr-S product. This is also a better option over ground concrete vs. some of the other products you mentioned as they are thin and would take many coats to look decent, imo.
Armorpoxy
Hi
We responded directly from our Customer Service Dept inquiry. Many thanks.
Garage Flooring
Grand Junction, CO
Hi everyone,
My concerns:
I was forwarded an email from staff as well. So lets have a look at your options and see what makes sense.
(1) All of these options are no film to thin mil coatings. They will not hide imperfections as well as concrete. All Weather Floors Polyurea https://www.garageflooringllc.com/polyurea-garage-floor-coating/ or Nohr S are going to provide the best coverage of the options you have selected. Although I would love to tell you 'my product is the best' the two are very similar and I think you would be very happy with either.
Ghostshield 8510 is an incredible sealer. We have it in stock, it ships the same day and it does an unbelievable job. There are rave reviews on 8505/8510 throughout the journal and elsewhere. As you say it does nothing to hide the cracks and as you say you can use it inside and out.
I do not like Rust Bullet for this application. If you elect to use it, I would consider an extra coat of gray, some flake and a clear coat.
I am not a huge fan of coatings in cold weather. Solvent based sealers do have less complications. I personally prefer to see a slab temperature of 50+
