SPGX/polyurea cure and Tucson (very) low humidity
drmarkr
Tucson
I've searched and not found an answer to this question.....will I have problems with cure if I apply SPGX to my one year-old floor (after acid etch) in the Tucson climate of approximately 10% humidity?
Any input from the vendors, or others that have used the polyurea's in low humidity settings??
TIA.
Armorpoxy
Hi, we have never had a curing issue anywhere in the country but if the humidity is very low it could slow the curing down.
dpr64
TIA.
When will you be doing the application? I am in Tucson also and if possible, would like to see the product in person after you install it?
Thanks...
Armorpoxy
One other note is that hot temperature speeds up the curing of SPGX so keep the material shaded and as cool as possible.
D
drmarkr
Tucson
Thanks AP. It will be another month or two before I have time to do the job.
DPR, I'll post up again when it gets closer. Message me your contact info and we can talk offline.
Armorpoxy
Hi contact info is in our signature. Please don’t PM as we don’t offer individual support is PM. Thank you.
