Spicymeatdong's Garage!
rday78
Spicymeatdong's Garage! Now with cabinets!!
This is the begining of the garage renovation. Taping *****!!! If it wasnt for that... the whole project would be moving along a lot faster. Got a coat of Killz on the wall and then went with cieling paint and sem gloss exterior for the walls. Had the rest of the fam over to lend a hand getting the plates on the wall.
R
rday78
More pics
R
rday78
Got the epoxy anchors installed! Also got the epoxy flooring in!
R
rday78
$70/sheet. A little expensive but it def makes the garage pop!
R
rday78
Havent added to thread in a bit. Got the garage floor done and got some serious work done on the work bench! Got the floor grinded... waterproofed and then put on an epoxy coating with quartz in it. Seems to be very tough so far!
R
rday78
Here is the work bench coming together. Thanks Steevo for the blueprint.
R
rday78
Some more pics!
bigbadjim
Saskatchewan, Canada
I like everything your doing there. Diamond plate is cool. Shop bench looks like something i'd build. Very nice. I'm curious about the MAX-jacks? Have you used the lift yet? Any good? Whats the lifting capacity of those and lift height?
R
rday78
Havent gotten the lift hooked up yet but it lifs 48" max and is rated for 6000lbs
R
rday78
Boxes installed in the benches!
R
rday78
Thanks... but not my idea. This idea was stolen from Steevo's thread... He did something very similar and I just modified his plans for my use. Check it out!
Steevo's Bench
NewShockerGuy
Northern Virginia / DC
Where did you get the round pads for the MaxJax??
I HATE The square ones that came with it because of how they can't turn and get bound up on the arm because of the angle that the one part of the metal raises up...
Garage is coming along! Looks great!
Thanks,
-Nigel
R
rday78
Round pads came with the lift... Might wanna call them up and see if they can send ya something. Here is the plate that will mount the pump and diverter to the wall. Tack welded the bolts in the holes so I have solid studs in the front. Getting paint now.
Johnny chaos
upstate NY
What type of material (the black) did you use along the top and bottom of the diamond plate? It looks awesome by the way
R
rday78
The black border is 1/4" x 2" pine. I routed 1/8" x 1/2" out of the back so it would lock the diamond plate into place rather than just sit on top of it
R
rday78
Thanks... Finally got the pump and diverter mounted on the wall for the lift. Should have an operational lift this weekend!
R
rday78
Thanks... getting everything to line up is a lil tricky... That and drilling 1/4" steel with a hand drill is tough
NewShockerGuy
Dang your pump looks different than mine too and others that I have seen here... I love that you have a drain plug on the reservoir...!
-Nigel
R
rday78
ok... lift is in and it appears to be working well except for a couple issues.
1. Lowering is slow.... real slow
I noticed there looks to be some adjustments on the side of the release block where the lowering handle is but havent found any info about it yet.
2. Had one side get stuck while lowering.
Gunna pull the lift apart today and make sure everything is greased well.
Other than that... Looks pretty pimp.
R
rday78
ok... got the compressor shoehorned into the last bay of the work bench... also had the countertops routed and slotted for biscuits. should have the top cabinets in on tuesday.
R
rday78
Ok.... a little update. Got the wood to mitered and mounted. Cabinets and led lighting is in. Even got a quad outlet in the center cabinet for phone, laptop ect. Just gotta get the back splash in.
R
rday78
Re: Spicymeatdong's Garage! Now with cabinets!!
Thanks... if it wasnt so damn cold in NY... the backsplash would be done... hopefully soon
Sent from my SCH-I535 using Tapatalk
R
rday78
Ok... havent updated this in awhile so figured id throw a few more pics up since its gone to the next level of pimptasticness!
bonecrrusher
Charlotte, NC
I need to lookup those round pads for the MaxJax as well.
We have very similiar taste in tools - love the lights below the Gladiator cabinents!
R
rday78
The round pads came with the lift. Lights came from superbrightleds.com Been happy with them.
