Looking for feedback on a repair/upgrade idea. I have a Dewalt 735 (Type 1) planer which is known for destroying it's proprietary induction motor ("2 hp", 120 vac, ~20K rpms and 14 amps running). It can destroy the armature or the field or both along with the casing. A entire motor replacement is not sold, but you can buy the parts and rebuilt it. But after hours of reading and am considering another route of repair: A Chinese cnc spindle and vfd. It should physically still fit in the Dewalt's cover, have high enough rpms, I believe has the torque. It will be a good 30% more to do this repair, but I think it could be the long term fix compared to another Dewalt motor that is likely to burn up after 3-4 years. From a rotational power device, I believe the spindle will have the torque and rpms to make this a very slick upgrade. Yes this glosses over the amount of effort it will take to mount the spindle attache the DeWalt belt pulley. I do have experience using, setting up, and configuring a Chinese spindle and VFD...nothing to learn on that facet of the project.
Question: Why might using a CNC type spindle with a VFD be a bad idea to replace a small proprietary induction motor ("2 hp", 120 vac, ~20K rpms and 14 amps running)?
If you are scratching your head on the "why" for effort/time/benefits: I like the physical size and features of the 735. I cannot dedicate the space for a 15" or larger more industrial planer.
For Reference:
Motor in the top left:
A typical Chinese Spindle Kit:
For Reference:
