Spinner handles
cheechi
Triad, NC
How often do you use screwdriver/bitdriver style spinner handles? I'm not talking about speed handles for engine building.
I have two, both part of sets. I am always finding a situation where a ratchet doesn't work as well as a nut driver would and/or just happen to have it out (stolen from the set) and end up using it throughout a whole project.
I have on the way about 6 of them to put at different parts of the shop and garage. Probably still won't be enough, and I have a 'full' set of nut drivers in the garage (not in the shop) but I'm hoping I can avoid stealing it out of the car or the other 'go' set as often. I think I might have some ratcheting setup that could do this lying around but it's never convenient when I want it.
I know it's not the most modern or **** way to use sockets but it's just one of those things I have always needed and rarely had when I wanted. How bout you guys?
winlinmac
USA
The one from Felo is nice, has a 1/4" bit holder, no ratcheting mechanism though
CoogarXR
I have a set of nut drivers, but I almost always choose the spinner handle and a socket instead. I especially like the spinner handles with the 1/4" drive square on the top of the handle, that way I can stick a ratchet on there for the initial break. It can also double as an extension if needed. I love 'em.
submariner
Western Australia
I use mine quite often. You'll get plenty more uses with a bit holder socket.
martin666
New Jersey
Have set of nut drivers, but I use these too. Handy when a swivel or deep socket is needed
redm18
Center Point IA
It took me forever to figure out what they were called and for some reason I never saw them at the store or anything but I remember using one from a cheap set my dad had as a kid. I found one at the Restore and picked it up then picked up a couple more at the restore. Really handy for electronics type work and car interior work.
Wamsutta
Amarillo, Texas
I use them all the time. Nobody makes a 3/4'' nut driver, so spin handle it is. By the way, I call them "spin handles." Matco nomenclature.
Big Pete
I use them a lot, in both 1/4 and 3/8 drives, really handy for dry builds where you want to just nip stuff up, but it needs to be a bit tighter than you can do with a bare extension.
used one yesterday to fix the dryer.
use them all the time working on lawnmowers - all 1/4" drive - no need for a whole mess of torque except for removing blower housing bolts that morons hog down to 900 ft. lbs. :eyecrazy:
This is probably my ALL TIME FAVORITE tool ! I love the square drive on the end so I can add a 1/4" breaker or ratchet for that little bit of extra torque !
As mentioned they are great substitutes for nut drivers when working on appliances or outdoor power equipment.
I don't know if Craftsman still makes one of these, but you HAVE TO get the one with the square drive in the top !
davethorik
Norka, Ohio
I have 2, a Wright 2442 with the 1/4 female in the handle. Also just picked up a Snap-on TMR4 ratcheting 1/4 driver. I'm quite happy with both.
panknuckshovel
Land o Lakes FL
Craftsman still has one part #43393. Snap-on ratcheting TMR4 is pretty freaking sweet as well
wolf_from_wv
WV
I use mine with ratchet on the end sometimes. I've never seen a 3/8 drive spinner handle...
I use my "1/4" drive" pass through spinner handle - would like to find a "3/8"" drive.
shockwave
Marietta,ga
Yes handled drivers in 1/4 and 3/8 work great I use them all the time great on spark plug installation too the best gave the female drive end aswell
panknuckshovel
Land o Lakes FL
honcho
Near Sodom & Gommorah (aka Wash. DC)
I have a ratcheting 3/8" drive one, I think it was made by Browning. It has not seen much use. I do use the 1/4" drive straight versions. I have the hots for the Koken 2769H but not quite ready to pony up $30 for it.
NthoozEist
I have a Motion Pro spinner T-handle that I use religiously. Can put anything 1/4" on it and go to work.
zkling
Quite often, although much less after I got a nice roto ratchet. Love nut drivers and with the spinner you can pretty much build your own. As mentioned above, I prefer the ones with the square recess for extra leverage when needed. Always leery of putting much torque on the ratcheting drivers, but for low torque they are handy. The craftsman/motion pro and other T handle spinners like NthoozEist posted are very handy as well.
MJD1
I like the harbor freight one that is extendable, with detents to change the length. Also has the female square drive on the handle.
Jim C.
I use nut drivers and spinners fairly often. If I have a lot of the same size fastener to tighten and/or loosen, I like to use my Snap On 1/4" drive ratcheting spinner/driver (#TMR4). It was expensive, but it works well, and sometimes it's the best tool for the job at hand.
raiderhillbilly
NC
The Proto J4769 is the greatest. The shaft goes all the way through the handle.
C
cheechi
Triad, NC
That Proto is on the short list of the ones I don't have. Probably going to have to buy about 6 more after starting this thread and seeing the variety available.
Just like someone mentioned my main issue with getting more was I had no idea what they were called until recently.
R.Anderson
Wisconsin
Have at least four 1/4" ones, one in a older Stanley tool set that stays in my truck, and three in my tool box. Yellow handle one no brand but says Japan, Powerkraft with with female end on the handle, and older Spintite made in the USA. For 3/8" and 1/2" drive I just use a extension, I add a thumb wheel when I need a little more.
B_Bimmer
Eastern Iowa
I have a Taiwan made Allen, right before apex gave up that brand, that has the female side on the top. Also lots of Proto's including one old one that I acquired broken where the shaft doesn't go all the way through like an overmolded extension. Apparently someone asked too much of the plastic. Also have a Mac one with that glorious red handle. I would love a 3/8's drive one but haven't come across one yet.
Rrumbler
Las Vegas, Nevada
Handy tool, these things. Grab whatever sockets you need, the handle, and you have whatever nut driver you need in less than a quarter the space; a quarter inch socket and a few driver bits plus the handle, same scenario. I have several, a few fixed handle and a couple of ratchet ones.
C
cheechi
Triad, NC
so the two on the bottom are what i was stealing from sets, both meant to live in different cars.
now i have some that have female options for use as extensions as well as the williams ones that i guess i can use a cab tip driver as a T bar.
and i think i have started a new collection in the process. the proto might be next.
bryan750
I like using spinner handles because you get a better feel for the torque you are applying.
winlinmac
USA
I prefer the ones from Williams, feels right in the hand, they're a couple available on Amazon in 3/8" and 1/4" drive configurations
drink
Confused State
I have several of the 1/4" drive spinner handles. They are a favorite to do work with. My small Craftsman mobile tool set has one in it and I use it frequently. I also have a few sets of nut drivers also. I think Klein makes a bunch of nut drivers with long shafts on them so they can reach deeper in hard to reach places. All I have to do is add an extension to my Craftsman spinner to be able to reach in tight spots. However, sometimes the separate pieces can fall apart and pieces can fall into tight spots. A long shaft can be helpful.
winlinmac
USA
I find these useful in hard to reach areas in the car (especially around the fuse box and glove compartment).
I've never come across any made in 1/2" drive.
Sine Swept
I've got a few spinners, Snap On w/ Female 1/4 on handle, Proto Classic, many no name in acetate. The worst I used was the Mastercraft Maximum that came in my carry socket set. I left it open in the driveway while working on a car in the summer, my spinner spun itself loose inside the handle, utter junk!
I have unfortunately a Mastercraft set (missing key sizes) of nut drivers, a very nice Pro Point in metric that doesn't skip too many sizes and are rubber handled and I keep a set of Milwaukee's in a custom holder on my small work bench.
^ originally made by "Vaco", until Klein bought Vaco. I see them now and then on Ebay - NOS sometimes - in the long-shaft version.
drink
Confused State
^ correct. the older Vaco models are the ones with the color-coded handles. do a search on Ebay and you'll see what I mean.
(now and then somebody will list one or two of them way cheap.)
