sky jumper
- Joined
- Mar 13, 2018
- Messages
- 127
I am replacing an existing 20 space subpanel with a 30 space panel. due to the size difference a handful of wires will not reach where they need to go (some hots and neutrals).
am I allowed to add "extenders" onto the existing wires to make them longer to reach the breakers and neutral bus?
if not, can I cut into the conduit outside the panel to add a junction box and splice the wires, and then pull a longer piece into the panel to reach the breakers? this would obviously be a bunch more work than just adding extenders in the panel.
if neither of these are code then I will have to pull new wires to the destination points, which would be the most difficult.
and similar --- I need to transfer 4 circuits from the main panel to the new subpanel. the only way I think this will work is to cut into the conduit and add junction box(es) and run extenders to the new sub panel. so hopefully this is code (I can't imagine why it wouldn't be) but are there any goofy codes that govern this? like you cant have a j-box within 3 conduit widths of the panel if there's more than 4 conductors in it or something crazy like that?.
