I think Wylie or someone spainedned an open neutral leaving the whole place ungrounded and the ideal is to eliminate as many stray neutral currents as possible, some may even be carried by earth. (Some of this is over my head and I certainly lack the capacity to explain it properly)
Again,,,,,,,,,,,,,,,,,,,,,, this. Whether we understand it or not the code gurus didn't change this because they didn't have anything better to do.
As I said earlier, the code and the inspections are there to PREVENT this very thing. Everyone installs it the same way.
My neighbor called me a while back with a problem in a modular. When I asked him what year it was built he looked at me kind of funny but knowing which code cycle it was under let us trouble shoot it without having to tear the place apart to figure out how it was wired.
Considering all the possible things that can be done wrong this is one of the most dangerous areas to neglect doing it the right way, the correct panel to panel connections eliminate so many potential problems and insure the fault protection works as it should. It also insures everything connected to this service is at the same potential.
As a side note if this was 3 wire an equipment ground bar would not be needed. It could all land on the neutral but we see so many wired incorrectly because the installer simply copies what he may see in one or in a main.
This is a poster case for inspections, conductors too short, wrong number and maybe even the wrong wire who knows. I was at a couple recent where the number of conductors were correct but wired wrong. When this happens the handyman comes back and wires the new additions like he sees and copies and it goes on.
Now since this has not been finalized man up and do it right, add another wire.
We need to be somewhat courteous here, if I kept getting this argument from someone I had working for me they would not be told so kindly especially after several attempts. At this point YOU DO NOT NEED TO KNOW WHY, now is the time to stuff it and follow instructions. Some day it will dawn, maybe after hearing it from someone else, maybe another day, maybe never
