Splicing #6 Al wiring
kschitoskey
Long time lurker, first time poster.
I've learned a lot from this forum and now I have a question. I'm installing a sub panel in my attached garage. I'm using a 50A breaker off the main panel, using #6 AWG XHHW Aluminum wiring. I ran the sheathed 6/4 wiring in the wall to a junction box, then 1" conduit to the surface mount panel approx. 25' away.
My question is this: I have to splice the #6 Al wires in the junction box (where I ran the wire in the wall to transition to surface mount conduit). What do I use? I know there are Al specific wire nuts but I'm hesitant for this size of wire.
Any help will be appreciated. I'm pulling a homeowner permit and it will be inspected.
matt151617
New Jersey
Split blocks work best. Put some antioxidant on the wires, tighten down the block bolts, shrink wrap the blocks, then wrap everything up with a lot of 33+ electrical tape. There's other options such as Polaris connectors but they're expensive.
kd3pc
Northern Neck
You might ask the AHJ what they require, as most wirenuts are not listed for AL to AL connections at all, and certainly not for two #6. Split blocks and a torque wrench with the best insulating tape/shrink you can get, if they allow it.
AHJ may tell you to pull it out and use copper, as using AL as you have may not be to code.
rockwithjason
Las Vegas
you can't use split bolts on aluminum unless the split bolt is rated for it. use insulated splice blocks instead. there is nothing wrong with the wire.
K
kschitoskey
I found Al split blocks at local commercial electric supplier, along with some heavy shrink tubing. Thanks for your help.:beer:
