Spline sockets
BigJ73
wisconsin
I am lookin for a set of 3/8" spline sockets. They would not get heavy use, so they do not need to be exspencive. Just need to work. Lol any suggestion.
Thanks
BigJ73
wisconsin
SAE. Probably up to 1". Price is up for debate. Would prefer something a little cheaper due to the fact that they probably won't see real heavy use.
General Geoff
Allentown, Pennsylvania
The only one I can find that's cheap and goes up to 1" SAE, also includes a full metric set.
Craftsman Max-Axxess 85-piece set
Because it's the Max-Axxess line, the sockets aren't entirely compatible with standard 3/8" ratchets and extensions.
Runs about $110.
I have an old-stock Facom-manufactured SK spline socket set, but I don't know if you can still get that one. list # 94545
BigJ73
wisconsin
1/2" would be ok. Here is a pick of what I will use them for.its a pulling tractor rearend. I would spin the ****** w them wile working on them.
bob15
Northeasten, CT
I don't believe a spline socket will work in your application. A spline socket is very close to a 12 pt socket.
Your small shaft has 7 splines, the other 10 splines. How will a 12 spline socket work?
Olafur
Iceland
The larger shaft has threaded hole in it. Find the right bolt and cut the head off ->turn with drill.
Spline sockets will not help.
2oolhound
BC Canada
How about putting the yokes back on and where the U clamps hold the u-joint drill a flat plate to fit across that end of the yoke and bolt it to the yoke using the 4 holes. Then drill a 3/8 hole in the centre of the plate, put a 3/8 bolt through and weld or lock on with nuts. Now chuck your drill on the end of the 3/8 bolt and go at it.
Or get a piece of tubing that just slides over the shafts, support the shafts with blocking underneath (so you don't stress the bearings) and with a round end punch pound the wall of the tubing into the valley of the splines so you form inner splines on the tubing. Next go to your reject tool bin where you keep those chi sockets you get when you buy a used tool lot, find ones that fit inside the tubes and braze or fasten them in. Now you've got some special tools for the task. As long as you're not trying to turn the whole drive line with your drill they should hold up.
BigJ73
wisconsin
I like the idea of trying to make/mold somthingover them. Create my own custom socket. Thank you for the ideas everyone.
retDAC
near Huntsville, Ala.
The Cman spline sockets, both regular and pass-thru, and spline wrenches will do pretty what Sears says, EXCEPT they won't turn even slightly rounded fasteners. And they don't grab like my other spline sockets will except for Kobalt.
The Kobalt spline sockets are combo sizes. The 14mm-9/16 definitely does not work for slightly rounded 14mm.
