catalytic
I need some GarageJournal group wisdom.....
I'm (finally) traveling for the summer and currently in a nice rental with a new-ish split A/C system. It is correctly set to 'cool' and the thermostat is set to the lowest, but it only blows air that is exactly room temp. On the outside of the house, I can see that the compressor/condenser unit fan is running and condensation is dripping out at a good/normal pace.
-I cleaned the air filters (which looked fine)
-I turned it off and on at the breaker
-if I turn up the thermostat, it automatically turns the fan speed down, and the fan speed increases again when I turn the temp down (so I think the thermostat is OK)
-I tried turning it off and leaving it for 5 hours. Still no joy when turned back on.
The owners are clueless, and it's going to be 95° tomorrow
---if you have ideas about this, I'd really appreciate it.
