Hey guys, first time caller. I have some concerns and questions about how my electrical system is grounded. I’m not an electrician and would like some opinions. Here’s what I’ve got:
Meter base sets on a 200 amp main breaker disconnect. Neutral is bonded to a grounding electrode. So far so good, I think.
[From the disconnect]
3-wire feeder (100 feet long) connects to a 200 amp splitter. The splitter has 3 bus bars (no ground). Neutral bar is bonded to the box and to a grounding electrode.
QUESTION: This is the 2nd instance of bonding the neutral to ground on this service. Is this an issue?
QUESTION: This electrode is NOT bonded to the electrode at the main breaker disconnect. Is this an issue?
QUESTION: Should this have been a 4-wire feeder to the splitter?
[From the splitter]
4-wire feeder connects to 200 amp Service Panel A (house). Neutrals and Grounds are separate and bonding screw is NOT in place. I think everything is kosher here.
[From the splitter]
4-wire feeder connects to 100 amp Service Panel B (shop). Neutrals and Grounds are separate and bonding screw is NOT in place. Ground bars are bonded to a grounding electrode.
QUESTION: Is this electrode necessary?
Thanks for looking.
Steve
[From the splitter]
[From the splitter]
Thanks for looking.
Steve
