splitters for craftsman 100 gold tablesaw
Enigma
Florida
are any riving knives/splitters available for these saws?
Shiftless
East Bay SFO
Yes!
They were available when the saws were new from Sears. Good luck finding one now.
You did a fantastic job restoring that table saw. :beer:
E
Enigma
Florida
thank you but that is not my saw. Its just a picture I borrowed to show everyone the kind of saw Im talking about. However. I will restore my saw and I will try to do so to the degree that this one is.
E
Enigma
Florida
i see a lot of them on ebay for 113**** does that mean they fit all 113 models? mine is 113.29991 from 1958 date code stamped on motor and tag
  • Like
Reactions: sgd
rickhigginshtbr
Lower Bucks, PA
just about all accessories from 103.*** and 113.*** are universal. Only difference I've seen is 10" saw accessories only fit 10" saws, 9" only fit 9", and so on.
6PTsocket
When that saw was made nobody had ever heard of a riving knife. There is not even a riving knife retrofit for the far more valuable Powermatic 66, which was the gold standard back then. However aplitters are a different matter. If your saw has a table insert, you can modify it, get another one to play with or make a table insert. Then you just need to cut a slot behind the blade and glue in a splitter made of wood, that is the same thickness as the blade. People make inserts all the time for zero blade clearance or to add a splitter.
McFarmer
A company makes a splitter that goes into the zero clearance insert.
Micro jig splitter I think.
micro jig
I've never used one but heard good things.
  • Like
Reactions: RTM
turbowoodworker
Apex NC
McFarmer has the answer. Search Microjig MJ splitter. I have used it on a newer contractor saw and it works well.
E
Enigma
Florida
what is the difference between a riving knife and a splitter?
McFarmer
A true riving knife goes up and down with the blade, and at the angle.
Much better, but very saw specific. Can be a pain with a small dado head, or molding head.
Your insert may have an opening for one, if your saw was so equipped. There may be a short stub behind the blade it mounted on.
6PTsocket
A riving knfe goes up and down but also tilts with the the blade. The European saws had it first but eventualy made it over here. I think there are retrofit kits for some popular saws like the Delta Unisaw. Otherwise, forget about it unless you are a designer with machine shop facalities. It is easy to add a stub splitter behind the blade, but just for vertical cuts.
McFarmer
I've never used a splitter or riving knife. Keeps long rips spread apart and from pinching the blade due to internal stress of the wood?
And prevents you from dragging the board to the left when finishing the cut and getting a kick back.
Also helps prevent cut offs from vibrating into the back side of the blade and getting thrown back.
