I know this thread is like so many before it, and I read a number of similar threads, but I'm still undecided, so I apologize for starting yet another mini-split thread.
I have a 40x64 pole barn (metal roof and siding) with a 12' lean to off the back (long side). I've built a partition wall to create a 24x40' shop that will be heated and cooled. The slab under the shop has 2" foam board insulation, and 900' of Pex tubing in three loops. The three exterior walls are getting R19 fiberglass with liner panels over the top. The ceiling has steel liner panels, a vapor barrier and then fiberglass insulation that's fairly thin (4' wide, 32ft rolls that made installation easy) with no specified R value, but probably around R11 or so. I plan to put enough blown insulation over the top to add R25 to the existing insulation. The partition wall is R13 fiberglass with 1/2" OSB on the far side. I haven't installed the interior overhead door, but it will also be steel on both sides, and insulated at least as well as the exterior OH door.
So, that leaves me with a 24x40' shop with 13'4" ceilings. There are three exposed walls facing North, West and South, and all three have low E windows (36x36"). The West wall has an insulated 10Hx12W overhead door...steel on both sides, R13 give or take.
It will be a while before I get to the radiant heat, so I thought I'd get a heat pump unit that will at least give me some heat until I get the radiant set up, and for times in the Fall and Spring where I don't have the radiant heat on, but get a cool day where a little heat would be nice.
My plan is go go with a single zone mini-split, but the online calculators are giving me wildly different cooling requirements....from under 10K Btu up to nearly 30K Btu. I'm leaning towards 24,000Btu, but wonder if 30K might be smarter? I'm looking at Mitsubishi units, so they're all inverter models that should prevent me from worrying about having too much capacity leading to inefficiency.
I'm also stuck going back and forth between the P series and M series. I plan to use radiant for when it's really cold, but it's nice to have a backup just in case something happens, and it regularly gets well below zero here in the Winter.
For reference, we've had stretches here in the Summer where it was well over 100*F every day for days on end, so it's not nearly as cool as many people might assume.
Thoughts?
Since we all love pics...here's one after hanging the ceiling and getting the lights back up. I took it to show the lighting in the middle of the night. The second was recently when I sheeted the other side of the wall, and the third was when I started on the interior walls.
Thoughts?
