Jawn
Howdy y'all,
First garage upgrade will be sufficient "juice" to run my compressor or other misc tools (120v 20A circuit).
See the pic for the basic layout - this is apparently a newer circuit run by a previous owner. Garage is in the basement, so the ceiling is open joists and walls are (currently) open studs but will soon be drywalled once everything else is squared away.
To explain the image... brown represents the breaker box. The yellow represents romex cabling. It goes from the breaker and up through the joists to the conduit of the first outlet, down the conduit to the quad box, then back up the conduit and into the joists again, across the stud wall, to a blue plastic in-wall box for four more outlets. Currently it's run with 14-2 and 15A outlets. I want to up-rate it to 12-2 and 20A outlets.
Now, I think it's only a 1/2" conduit... I can go bigger, but at the same time I've read that romex in a conduit is a no-no... but some say it's ok for a short run like that? So do I put a junction box at the top of the conduit, run romex to there, individual conductors to that quadbox, then more romex to the other box, or do I just replicate the existing wiring (just with larger wire)? Next question, do I daisy-chain the outlets in each box, or do I wire nut two short pieces of wire to the incoming wire, and connect each of those to each duplex outlet?
