Spray bottles, what works
My Old Tools
Hamrick Lake, TX
I'm looking for a good spray bottle that will handle kerosene, WD40, acetone, etc. Hand pump, trigger, rechargeable air pressure....what works?
NUTTSGT
Northern Central Ohio
I have my WD-40 in the squirt bottle that came with the gallon can. I also have some other oils, tap free and Kroil, in some squirt bottles that I got when I worked at GE. Those were probably bought in bulk from Grainger or MSC. They have worked for 17 years plus.
BD1
north side
I have a couple of the '' SURE SHOT '' sprayers and work well. Mine are around 10 years old.
flat tire
hills of wv.
I have never had a problem reusing any commercial spray bottle.
right now I have kerosene in a glass plus spray bottle
AMCguy
Sunshine Coast, BC Canada
I buy Spray-Nine in the one litre spray bottle. It has the best sprayer I've ever used. You can turn it from off to spray or squirt. It works as good as or better than and lasts longer than any expensive janitors bottles I've bought. And they are all the same so storage is easy. I find expensive janitors bottles are always cylindrical and fall over easily when you accidentally bump them on a shelf.
I have so many empty Spray Nine bottles, that I use them for everything from weed killer to ArmorAll.
Now I just buy my liquid shop supplies in one gallon refills.
And by the way. Spray Nine is the best cleaner I've ever used.
torqueman2002
Woops, a little slow.
Anyway, ....
Brakleen (Brake Clean) can be purchased in gallons, non-aerosol. ~$26.00.
Train
Alberta, Canada
I haven't been able to find any type of trigger type spray bottle that will last with acetone. It doesn't take long before the seal goes to **** and they won't spray.
torqueman2002
I found that happened with WD-40, but with an WD-40 branded spray bottle it was OK.
Must be different style seals.
Have you tried a WD-40 bottle?
Nor'Easter
Maine
The ones that Chemical Guys sell work well with everything, including professional wax and grease remover.
