brianpgriset
about to sign papers on a new shop.
30x60x14, stick built, 2x6 walls, 2ft truss spacing on roof, metal panel exterior, plain and eaves with no soffits, vented ridge cap.
I want to finish the inside with drywall or osb on walls and drywall or metal panels on ceiling. Want to run electrical in the walls.
First plan was to do batt walls and blown in insulation on the ceiling but with no sort of soffit vent I was worried about moisture. I like the idea of foaming the entire thing but I see two problems I wanted to ask about:
1. Has anyone foamed a wall cavity but left enough room to still run eletrical? IE I get three inches of foam in the wall bags which still leaves enough room for running wire, then finish over that. Is this OK?
2. I want to put up a ceiling. Can I just put up a ceiling with no vents to the attic? I plan to add air conditioning but not run it 100% of the time, maybe only 30 or 40%. Will this cause issues?
If you have a spray foamed building with a fully finished intdrior, could you share your setup?
Thanks.
Thanks.
