DC has it right.
The vapor "barrier" in most construction is really just a retarder. If the steel were air-tight, it would be a vapor barrier; on the wrong side of the wall assembly.
The reason we use a vapor barrier in construction is simple to protect the wall insulation from getting, and staying wet. This is a cold weather phenomenon since the inside of the wall assembly must reach dew point and condense damp cold air leaving the inside of the wall holding the moisture and losing its R-value at the same time. Then of course there is the mold issue.
In steel buildings you will have a nearly perfect vapor barrier in the metal exterior more especially if you foam it. However, again in cold climates, if you can't dry the wall to the outside you must be able to dry it to the inside. If you are not dehudifying the inside you have no path for vapor. If you are not creating vapor, showering, cooking, etc. you have no vapor to get rid of.
I model many steel buildings for heating and cooling systems, most are in cold climates but a few are in the dry heat of the south west with many in high arid planes such as Albuquerque. In these places and many others, a radiant barrier makes sense, more especially on the south facing walls and roof. I am not talking about bubble foil--a nearly worthless product in any application--but rather rigid foil-face foam. If placed underneath corrugated steel you have natural convection to the ridge vent and may cut your cooling bill in half.
Here in Minnesota I started with a R-5 on all exterior, made air-tight with foam and then proceeded blow fiber-glass in netting with 5/8" rock on the inside. I actually had to take the plastic vapor barrier down, since my builder was not listening.
18" of cellulose sits on top of poly at the the 10' ceiling in this office area that will be cooled.
On the garage side it will be the same but for the lower design temperature and the lack of a vapor barrier, since the humidity will not be controlled and assumed to be the same as the exterior. I will be fiberglass to the inside of the R-5 foam.
Beware new foam applicators, since the quality of the foam depends on the skill of the man foaming both in mixing and in spraying. T
The reason 2" is preferred is because more than two inches can create enough heat to start fires. More can be applied after it cures. It is a great air-sealer and I used it from the rim-joist to the ridge-line in the 1921 balloon from farm house next door.
