Spray foam kits?
Hchrist
S.E. NC
I responded to another thread but figured I'd start another. Anyone use the spray foam kits? I have a 33X22 shop with very high ceiling and no insulation. It's been built for several years and I'd love to have insulation.
Galaxy S4, Slimkat
If I wasn't married I'd quit fishing :)
PCustoms
VT
Subscribed, need to foam 1300 sqft of joist bay and looking at kits too. I've been leaning towards foam it green because the 2 components are colored, green foam indicates a proper mix and yellow or blue tells you a hose is plugged.
Seubs070
I used the foam it green kit on my kitchen remodel. Worked really well and I am happy with it. Once I got the hang of how much to spray to get the proper thickness it was pretty easy. Took a couple coats to build up to the 2.5" thickness I was looking for. Makes a mess too, so make sure to cover everything with plastic.
Lastly, get some quotes to have to sprayed. I was able to get a deal on mine from a friend that bought to much and sold them to me. If you pay retail for the kits, you are close to the cost of just having someone come out and spray it.
Voi
Western South Dakota
I priced the kits this past summer and they were more expensive than having a professional outfit come out.
My project was smaller than yours and was also out of town and semi-rural.
I compared the kits to professionally installed closed cell. I did not check open cell prices.
For reference, the professional installer was 85 cents per board foot.
Streetbu
Central NY
I would highly recommend getting some estimates from a local spray foam expert first. When you realize how many kits you'll need to do your shop, then how easy it is to mess it up the first few times so you'll have to buy extra kits, you'll see it is usually cheaper to have an expert do it.
joe_padavano
Northern VA
I used Touch-N-Foam kits to spray foam the inside of my 28x32 metal building. Bought them on ebay. I needed four of the 600 sq ft kits to complete the building. Two pieces of advice:
1) Pay attention to their temperature instructions. The stuff does not spray or expand below their recommended temps.
2) Be sure all exposed hair (including your arms) are covered. :scared:
Do NOT ask me how I know this...
86turbodsl
I bought and used 2 600ft kits for spraying ductwork on my house. The thing you need to remember, is those kits are rated at the MAXIMUM possible coverage under ideal conditions. You will not be spraying in ideal conditions. the coverage will be less.
I think kits can be an effective solution if you have issues that prevent a contractor from spraying efficiently. In my case, i was spraying ductwork in my attic buried in cellulose, and i was not able to uncover all ductwork concurrently. Kits made sense because i could work slowly and carefully, which a contractor won't want to do.
#1 rule of thumb: You cannot purchase materials to spray foam cheaper than the contractor can complete the job for.
The contractor price should be about a $1 a board foot. That's installed. In my experience, having done a full house for over $10K in spray foam, you can't get it done any cheaper than hiring a contractor if you have a building ready to spray and they can get at everything easy.
And i looked at every possible way to cut corners including buying equipment and even MAKING my own equipment to spray foam sets. There's just not many shortcuts. My experience anyway.
joe_padavano
Northern VA
This depends on your location. Here in the D.C. area, all contractors are expensive. In addition, by doing it myself, I did it on my schedule, not theirs. The PITA of waiting for contractors who don't show up when promised gets old VERY quickly.
gdrum
I just put a flat roof on a 1500 sq ft building. Does anyone know if I can just spray these kits on the inside just right under the inside of the roof? Or does there need to be some sort of barrier that goes down before spraying the insulation on?
James-W
Southeastern Wisconsin
I have heard more than once you can hire the spray foam done for less money than doing it yourself. If I were to get spray foam for a project I was doing, I would definitely check prices and get quotes before I did anything.
mrpizza
IL
Those frothpacks or whatever kits are a lot more expensive around here than hiring it out.
Oldbear
Linden, Alberta, Canada
It runs along the same lines as pouring your shop floor with 25kg cement bags. Sure it can be done - but it will take longer, cost more and not be as good as getting it in one shot from professionals. This is one of the things on my "not my wheelhouse" list. I'd use one kit to do a kitchen or bathroom or a repair; but an entire building - No.
