Spray Foam Pro Gun - Fan Tip
Fix Until Broke
SE Wisconsin
I'm looking for the little plastic tip that goes on the end of the "standard" spray foam guns with the removable canisters to be able to spray that foam in small areas like shown below.
I was able to find the company that has the product shown in the video where I snagged the above screen shots, however I believe they're Russian and don't seem to have any distribution in the USA (or North America for that matter).
https://www.polynor.ru/en/products/insulation-polynor
It looks like the tip comes new on each can of insulation you buy?
Does anyone know of something similar available or any way to get these tips?
I am aware of the 2 part kits that are available (and have used them successfully) but something like this plastic diffuser seems like a much better solution for small areas or for anywhere that you don't want a round bead.
The gun looks like the standard "14" gun that everyone uses - Any thoughts, ideas, suggestions, etc?
The Cobbler
I'm wondering if that foam is a different consistency. I am not sure you could get those results with regular spray foam . I would experiment with a pc of pipe flattened on the end and slipped over the gun tube
Rusty Musket
The gun and canister look very similar to the stuff I have. That tip could be very useful for air sealing a large surface with a shallow coating of foam. I hope we can find that tip somewhere because I would love to try it.
seagull369
I often wonder why there isn't a "Great Stuff" type canned foam that you can spray similar to the gazillion dollar 2-part poly foam kits out there. There's certainly a market for it. Perhaps it just isn't possible on those kinds.
