billconner
Had not read of this here but saw this on another site and found it interesting.
"For the past 15 years or so we've been making the recommendation to install spray foam for any insulated concrete slabs. We prefer a tamped crushed stone base and the spray foam can be installed in a fraction of the time over the entire area as compared to conventional foam board insulation.
With our material there are no seams, breaks, joints, etc. that you'd experience with foam board so the install is much more reliable. Furthermore, in its inherent qualities, it provides the vapor retarder that is typically achieved by using poly/plastic.
The added benefit is that the spray foam has a strength that is more than enough to withstand the weight of the concrete and vehicles and for basement applications - it doubles as a radon barrier!'
