nemise
I noticed that a lot of people use XPS rigid foam boards under the slab, and that most recommend using boards with higher PSI than 25 so the slab and cars do not crack it underneath. I see that foamular makes 40, 60, and 100psi boards. Am I better off going with spray foam underneath? Does spray foam have a PSI rating as well? Where would I find that info?
My thinking on using spray foam instead of separate 4x8 boards is that the foam would be all one complete unit, rather than about 30 separate boards, making it more level without high/low spots, reducing the chance of cracking.
Thoughts?
Thoughts?
