I have an older Devilbliss Suction Fed Spray gun. I use to use it about 20 years ago to spray paint lacquer and enamel paints. The gun is in fine shape.
I'm a little rusty on using it.
What I'm planning to do with it is spray from enamel paint on a wooden door. I'll be spraying outside using my plain old 110v air compressor.
Years ago I used to have a water seperator/filter for my air compressor. It broke and I never got another one.
I'll be spraying Sherwin Williams enamel paint onto "old" wood that has been sanded.
I need a little advice.
What line pressure should I used? I'll be using about 25' of hose and I need to set the pressure accordingly.
What about thining the paint? I think I used to use "paint thinner" to thin it but how thin do I want to make it?
I have a very nice filter to strain the mixed paint through into the gun. Any trick that would help in this regard?
I have a nice mask to spray with. I bought it when I was spraying lacquer. I guess the cartiridges in it are still good. I won't be spraying in a booth so I'm not too worried about this.
Are there seals and valves in the gun that might go bad? My guns been sitting up for about 20 years.
I've sprayed lacquer and paint before with this gun. When I bought it gravity fed guns were not around. I looked at the gravity guns and just can't justify the costs. If my wife didn't want a specfic color, I'd just rattle can it.
Comments and suggestions are welcome.
Thanks.
Thanks.
