I painted the interior and exterior of my large house and others with an air less. If you have a professional grade airless unit, the walls come out incredible smooth in one coat, rolling would just rough up the surface and slow you down. Primed the entire interior of the two story in 1 day, finish coated all the ceilings in 1/2 day, final wall coating with 3 color changes in 1 day. Masking is a time consumer, used 3" tape, 1 long day.. get the best masking tape or the paint bleeds.
I would not (never) use gloss, it shows up imperfections in wall prep which you will need to inspect with a hand held light and by hand feel over every square inch of surface before spraying..sort of like auto body work, "nearly flawless" won't do it. If you must have a gloss your best off with an egg shell or satin finish, which will still require careful wall inspection/corrections before spraying, but 3x times less then gloss. As mentioned, any repair/modifications with a bush or roller will show. Lastly, if want smooth, you will need to spend about 20-30 minutes per room for a quick sand of the prime coat.
