Time to get rid of some stuff. Little different than normal for this forum but worth a shot.
Back row left to right.
A.O. Smith 2 speed 3450 1725 56z frame runs quiet 10.8 amp at 3450 3.0 amp at 1725 120 volt. 1/2" shaft. The little plastic nubs on the face hold the nuts I never bothered switching for regular nuts. $10 plus shipping.
Gorman Rupp metering pump I never used it but it does work. free you pay shipping. Dont know specs wont flow much.
B&B gear motor .33 amp 1725 rpm one side gear reduction on the other 18:1 96 rpm shaft can be clocked in 4 positions has a 5/16 shaft (both of them). Comes with variable speed control reversible.
2.3 amp March motor with a magnetic drive centrifugal pump. Will pump flammable etc. It is too much pump for a parts washer. Has one issue there is a little bushing broken that lets the spindle ride out and scream it gets quiet when it is pumping but it will wear the plastic body on this thing. Should be an easy fix. $10 plus shipping.
5.8 amp Gould century motor L48 frame. Has a flotec pump head on it. $10 plus shipping.
90 volt DC motor 1/2" shaft shaft is a little rusty but it is brand new dont know any other specs on it. $10 plus shipping.
Cole parmer 1.8 amp 7500 rpm motor with a micropump head. These make great partswasher pumps, run about $800 new. You have to use a speed control or a big hose at full speed they flow a little too much. This one has a broken magnet on the drive arbor if you can find a replacement it will be good as new. The one on the left is not for sale just to show the difference in magnets. The pump has pretty small passageways so you have to use a filter and loop your hose below the intake so that when you shut it off the pump head isnt the low spot where the crud settles. $30 plus shipping. I have a filter and cartridge for $10.
Next up is a mystery, little motor with a belt. free for shipping or trash in the morning.
Blue Point ap10 pliers good shape engraved $15 shipped
Blue point ya 3080 cv boot clamp pliers $15 shipped
