Sprinkler System Backflow From Elevation Change
Nessism
Torrance, CA
I just finished installing a two-zone sprinkler system in my backyard. One zone has a small area that's at a higher elevation than the control valves, and when the solenoid valve on that zone closes, water backflows and splooges out the anti-siphon portion of that valve.
I'm thinking about installing a secondary Pressure Vacuum Breaker valve in the system, to further protect the potable water supply, but that won't stop the water from backflowing out of the control valve every time the system is used. I wouldn't mind the water dumping when shutting off, but I'd like that to happen off the patio. Maybe add an additional vacuum breaker, just off the patio? Open to suggestions...
Screenshot 2026-06-15 061538.pngScreenshot 2026-06-15 061559.pngScreenshot 2026-06-15 060851.png
Shiftless
East Bay SFO
The instructions for anti siphon valves say to install at least 6 inches ABOVE the highest sprinkler head.
So to prevent water from back flowing onto your patio, you an either raise the anti siphon valve or install an electric valve and a dual check valve assembly to replace your anti syphon valve.
They are complicated and expensive. That’s why I raised my anti siphon valves 2 feet above the level of my patio. 😎
N
Nessism
Torrance, CA
Yes, the anti-siphon valves needs to be higher. Adding a check valve is not the ideal fix. Guess I need to redo the plumbing. I'm going to order a proper Pressure Vacuum Breaker valve, elevate that 12" above the highest sprinkler head, and then use simple solenoid valves to control the sprinkler system. Removing the solenoid valves with integrated vacuum breakers. Kind of frustrating, but the plumbing will be simple enough. The valves can go under my box, but the PVB will stick up a couple of feet.
Shiftless
East Bay SFO
Your wooden box looks nice. Just build a skinnier one to cover the piping and the vacuum breaker. If you don’t build a box or at least paint the pipe, the PVC pipe will be exposed to sunlight UV that will badly degrade the plastic and make it quite brittle.
larry4406
Northern Virginia
Not sure if this is relevant, but at the day job, we have pumped septic systems called “drip irrigation”.
They are small diameter tubes (3/4-1”) that are perforated and shallow buried in an array.
The systems pump up hill to the field, turn downhill to meet the distribution box, then down hill thru the lines.
There is a vacuum breaker at the top of the hill. It closes automatically while pumping. After the pumping quits, pressure decays and the lines drain and the effluent prior to vacuum breaker drains back to the pump chamber.
Wrench97
Southeastern Pa
Can you elaborate on why a check valve is not a ideal fix?
N
Nessism
Torrance, CA
For one thing, I don't think they are sufficient in a case like mine to make the system meet building code requirements. I'm not permitting this, but just saying. Secondly, those cheap check valves are not reliable. No big deal, I suppose, as long as you can get to them.
Wrench97
Southeastern Pa
You would still need the vacuum break, but the check valve down stream towards the sprinkler heads would stop the flow.
There are decent quality check valves on the market if you hit a supply store.
N
Nessism
Torrance, CA
The control valves have a vacuum breaker built in.
I'm changing my mind on how to fix this. Thinking now that I'll lift up the existing valves. 12" higher than the existing position will work. I can do this in just a couple of hours. It will look a little unsightly, though. Have to make a new box that's taller. It's either that, or buy a $150 Pressure Vacuum Breaker valve and new control valves that don't have the vacuum breaker feature built in. The PVB will have to stick up regardless, but that's not quite as bulky as the valves.
dcg9381
Austin, TX
I just want to say this is some bad-*** GJ sprinkler system.... Around here, we put this stuff in the ground, but not on GJ. We do it full Monty...
Apparently not completely to scale if that's 1/2 or 3/4 pipe... But still. This is a manly sprinkler system.
