I just wrap the pipe with a piece of paper, then mark it with a sharpie. Then you can cut it with whatever you want.
I'm sure that worked well on the Trans-Alaska pipeline, but it's PVC. Isn't eyeballing it just fine?
It’s new pipe. I’ll give the old miter saw a shot. Hadn't occurred to me for some reason. I can already smell melting pvc
Have a VERY good grip on the pipe, go slow and it cuts on the miter saw wonderfully. No melting (if your blade is sharp), but the chips are very static clingy.
The danger here is the same as cutting anything round on a miter saw. It wants to spin as the blade contacts it, and that can easily bind and turn to a brown pants moment in an instant. Cutting slow reduces the chance of it kicking by a lot.
Be aware that pvc pipe might decide to shatter and explode when cut under power. Have a good set up. Wear safety glasses.
NEW PVC tends to be far less brittle than old PVC. I will suggest that you don't attempt to re-use any old sections of pipe, no matter how good they look.
Oh, as for in-place cutting, when I renovated my last bathroom, I needed to tie into a 3" PVC main that was hacked with a sawzall. I ended up buying a $10 blade that you chuck in your drill and use to cut the pipe from the inside. It worked GREAT (much easier than I was expecting), and made it super easy to get a surprisingly square cut.
