Square D 220v to 110v change over
DavidR8
Victoria, BC
I have a Square D magnetic switch on my Unisaw.
I need to switch everything to 110v until I get my 220v service finished.
I’m not quite sure how to change the switch wiring to 110v.
Hoping someone can interpret what I’m looking at.
Dozerhand
Illinois
You need to find out if you have a dual voltage motor. I have an older unisaw and it will only run on 220.
GrayFlattop
Chicago
This. And if the motor is dual voltage capable, you will need to reconfigure the coil wiring - per the schematic. Also, you will need to swap out the heaters - based on the FLA @ the lower voltage. And you may need larger wires since the amperage will double.
D
DavidR8
Victoria, BC
if it's a 3 hp unisaw I don't think they are dual voltage motors. if they are, the amp draw will be high on 120v. can you run a temp 240 cable to power it up?
I think that’s what I will am going to do.
Thanks all.
