Square holes in the ceiling
TheClaw
Chicagoland
Having some issues with my new shops ceiling
Looks like the electrician and the drywall guys didn't coordinate well. After light we're installed I'm left with this.
Any ideas to block off some spare boxes and the four with wires?
The Cobbler
you need to keep access to the junction boxes so you can't do anything that permanently covers them . probably many ways to skin the cat but I would look in the boxes to see if they can be lowered to be flush with the drywall then patch around them & reinstall the covers .I am also wondering if that lampcord is kosher being connected like it is :headscrat
sparky 1971
Central Iowa
mm08822
The box should have had a mud ring to accept a cover after the drywall was installed and painted. Not sure why a single gang new work box wasn't used in the first place.
The electrician should have never installed that cover or the zip cord. The zip cord raises BIG FLAGS.
Snap-on_rich
What a terrible install. What concerns me the most is that lamp cord. Is that really what came with those fixtures? I'd like to see some sjtw cord from the manufacturer or some field supplied 3/8" FMC... and they forgot the mudring!!!!
gatewaysysop
Arizona
Why put up with shoddy work from people that you're paying for professional installation? I wouldn't waste my time fixing their @#$% up, much less more of my own money. Don't these folks stand behind their work and have some sort of standards they're accountable for, as licensed professionals? :confused:
sparky 1971
Central Iowa
I don't see a way to get out of a little drywall repair. I would do just as @sparky 1971 sugests and put a proper mud ring in. For these, I use metal finish plates and drill a hole for flex conduit to make the wires clean:
As long as the hole is cut tight to the box, and it appears to be that way, a two gang blank should cover the entire hole w/o any drywall patching. I've cut out many single gang rings and replaced them with two gangs and the plate hid everything.
mm08822
Whatza goof plate?
Nevermind. I googled it and I have seen them installed but haven't needed one...yet. They look like ****.
They look terrible! I would do a drywall repair before I walked away from a job with them installed by me. (And I have gotten good at drywall repairs over the years. It's a selling point when you can tell a customer that you can fix any opening required.)
Chuckster in NJ
Hunterdon County NJ
Nowadays MOST people accept substandard work as a standard.…… OP should have contacted the GJ peeps BEFORE he paid these hack contractors in full. :rant:
mm08822
More q's for the OP.........
Why are there 2 pieces of zip cord used?
Does the zip run box to box behind the sheetrock?
T
TheClaw
Chicagoland
What kind of flags?
What a terrible install. What concerns me the most is that lamp cord. Is that really what came with those fixtures? I'd like to see some sjtw cord from the manufacturer or some field supplied 3/9" FMC... and they forgot the mudring!!!!
That is the chord that came with the fixture.
So was it a licensed electrician who did this?
There are 2 electrical code violations shown.
Was it inspected?
What violations? Yet to be inspected.
That is the chord that came with the fixture. There is a connector one the chord into the fixture. The second wire is for the dimmer.
T
TheClaw
Chicagoland
Absolutely a good selling point. I owned a painting franchise for 9 years (not a good move) and as painters I told customers we could repair most anything inside or outside. That way customers did not have to deal with multiple contractors.
mm08822
What kind of flags?
Red flags.....big uns, neon.
I doubt the zip cord was approved as part of the fixture wiring running in free air. Have a link to the fixture?
Does the fixture require a ground wire?
Use of Nm-b squeeze connectors are not approved for zip cord. They are listed for various sizes of NM cable only.
The box should be within 1/4 of finished surface. NEC 314.20
Any gaps in surface finish > 1/8" should be closed. NEC 314.21 Possibly not an issue here, depends upon how NEC 314.20 is accomplished.
How many of these boxes are there?
mm08822
BurtEggley
I handled that by having boxes with receptacles set properly. Then plugged in the ceiling lights. Electrician and Inspector were totally Ok with that. The UL and NY approved chandeliers we have in the house use lamp cord weaved thru chain. There might be applications where it is allowed. I don't know.
T
TheClaw
Chicagoland
Those are the wires that came with it. Each one of them had a connector on one end where it plugged into the fixture itself
Chuckster in NJ
Hunterdon County NJ
TRUE…….. But they also have a bare copper ground wire that gets "weaved" into the chain.
Snap-on_rich
wow theres no way that fixture got listed with the 2 conductor zip cord and no grnd wire seeing as how the fixture is metallic.... yikes :shocking:
I thought the same thing. Or the got it listed without supplying wiring and sone guy in china thought it would sell better showing sone cheap scrap on wire in there amazon listing. Alot of products on Amazon claim to be etl and ul listed and its just fake labels..
