First off, this is my first post, I have been trolling for quite awhile now and have gotten a load of great information and ideas along with drooling over some of the projects and shops.
I own an auto repair shop and have struggled to find a quality engine support bar (transverse bar). For those of you unfamiliar this is a bar that supports and engine from the top side while dropping the sub frame or transmission out of the bottom. Anyways, all the ones I have purchased or used didn't have the adjust ability that I need so I decided to build my own. Problem is I don't know how big or heavy the square tubing needs to be to support the weight. I am guessing that 2"x 2" square tubing with 1/4" wall will hold but I know there is someone here that can tell me for sure. In the most extreme of circumstances there will be a load of 1000 lbs in the center of a 60" span. Considering I'm the one standing under the thing with 1000 lbs over my head
I am defiantly using the rule of 5/3rds so I need the thing to hold about 1700 lbs.
If anyone knows of a chart with the info I need I would be greatly appreciative.
Thanks
Duane
I am defiantly using the rule of 5/3rds so I need the thing to hold about 1700 lbs.If anyone knows of a chart with the info I need I would be greatly appreciative.
Thanks
Duane
