square
brownbagg
how picky are you about getting your project square, do u go after the gnat azz or is 1/8 close enough.
Vegaman_Dan
Pacific, WA
When welding a table frame or cart frame, I want it as square as possible, but I'm not going to sweat 1/8".
For a vehicle project, I want that baby as square as possible, and 1/8" can really become magnified in other measurements later. Worth the time to do it right.
It's all about scale and final use.
RivennHewn
PNW
Foundations - 1/2".
Framing - 1/4".
Cabinets - 1/8".
Cabinet knobs - 1/32".
Furniture - Square
Depends on the project.
kazlx
Tustin, CA
I'm generally pretty picky about measurements. Framing a shed, 1/8" is fine, building a metal cart, an 1/8" would bug me to no end. Like everyone else said, it depends. I've found that taking up machining as a hobby tends to make you more **** about other things when you get used to measuring with calipers.
383 240z
Findley Twp. Allegheny Co.
Like everybody else said depends on what I'm building. Framing I'll live with 1/4" block work I'm happy at 1/2" if I'm in the machine shop anything over .005" I start getting pissy. Keith
larry_g
oregon
Square is normally measured in degrees. Four 90* angles and 4 equal length sides are considered a square.
lg
no neat sig line
INSP380
Cleveland, Ohio
I like to hold my squareness to .2 of a degree as the norm. We use .5 on some loose tolerances. Sweat the details till it becomes second nature. Shoot for zero, but hold your tolerances. Nice parts will follow.
Fab work here, not machine work.
Steve
