I have a problem with the dimension of a concrete pad that my contractor poured. It’s for a 12’ x 18’ barn that’s going to be installed on top of it. The concrete pad is going to be the floor so the walls will be fastened to the concrete pad.
The barn company said the dimensions need to be 143” x 215” because the wood siding will extend below the concrete pad about an inch. So, the pad is supposed to be 1 inch shorter on each side than the overall barn dimensions in order to accommodate the siding. The wall sections and trusses have already been pre-built at their facility so it’s not like that can adjust their build on the fly. It is what is from their perspective.
The problem is when they poured the pad it looks like the forms bowed causing a large section of the pad to be about an inch wider than it should be. I would say there is about an 8-9 foot section of the 18 foot length that’s impacted.
Is there a way for the contractor to do something to bring it back to the proper dimensions without destroying the pad? I’d really hate to see them try and saw cut a precise line to achieve the desire result as they failed to cut a straight line for the control joints. Not sure if they could use a grinder or something of that nature to fix it. I have to meet with the contractor tomorrow so I just want to be prepared for his suggestions.
