Squirrels eating wiring
sdowney717
Estimate is 30,000 house fires a year from squirrels?
so why dont codes require metal armored wire in wood framed houses like the old timers used?
That sounds like a lot of fires caused by rodents.
racerbob4
Northern Virginia
Go directly to Home Depot and buy a squirrel trap, then to the grocery store and buy a jar of peanut butter. Squirrels love peanut butter and you need to catch all of them. When I had a squirrel problem I took them to a local park that is close and set the free. Then look over your eaves under the gutters and find where they are getting in and install some wire fabric that is stronger than screen wire and problem solved. I took out 16 squirrels one year.
carbons4
New construction I would always go for the Armex(metal shielded wire). My house I went one step further and pulled romex inside EMT. My friend lost his barn and several rare cars (one was a 69 Charger 500) because of a squirel eating on wire. You might think it's expensive when you are paying for it but the piece of mind is worth it.
Stuart in MN
Minneapolis
Because 99.99% of the time the wiring is protected from squirrels because it is inside the building. You may as well have a building code that requires all houses to be made of sheet metal so the squirrels can't chew through.
SMKS
USA, planet Earth
I'm thinking of buying one of these to kill squirrels that have been destroying my garden.
I've only read comments by a couple people who said they work on squirrels. Some websites say it doesn't.
# Q: Does the Rat Zapper work on squirrels, ground squirrels, chipmunks, moles, gophers, groundhogs, possums, raccoons, birds, cats?
A: No, the Rat Zapper is strictly designed to work on rats and mice. However, we have had customers who have used the Rat Zapper to help control ground squirrel populations successfully.
I read somewhere that squirrels are hesitant to enter boxes that don't have openings on both ends, which is why squirrel traps usually have doors on both ends.
Jagmandave
Overland Park, Ks.
Doesn't seem to bother the squirrels in my 'hood, as I've been using a Havahart trap open on one end to trap chipmunks, which can do huge damage as well, only from a different angle - they tunnel under your driveway, garage floor and/or foundation and undermine it - next thing you know your driveway's 6" lower than you garage slab! Anyway, I've had plenty of squirrels in that trap and like I said it's only open on one end.....
Don't bother to trap or kill all of them, for every one you do 10 more will move in due to the lack of competition! You may make a temporary dent, but they'll be back......
The only thing you can do is trap and kill the ones that have gotten in, then figure out how/where they did and fix it so they can't get in again. Sometimes just getting rid of the "problem child" does the trick, as not all of them are predisposed to getting into the house. Do the usual safeguards (trim back the trees and such) but in my house they climb right up the chimney.
On my house they tore off cedar roof shingles over a dormer and tore thru the soffets too. I put metal flashing under the shingles and alll along under the soffits when I rebuilt the damage, so if they started scratching on the wood they'd hit the metal - so far so good.
Good luck!
sdowney717
Ok, but the squirrels are getting into the attics. I would say the attic space ought to have armored wire, possible crawl space or basement also. Inside house walls is not as critical. I do suppose they can eat thru wood framing. I had one gnaw a 2 by 4 almost in half. They chew so much as their teeth constantly grow.
Sometimes I can hear them running across the roof. They dug into my soffit area by the fireplace and nested and then the soffit fell off the house. I think they climb the trees and jump onto the roof.
MBfreak
MEMBER EMERITUS
Linkoping , Sweden
I love the lamps, but they may result in tangible evidence.
Squirrels are protected here, and hunting in the suburbs strictly forbidden.
I shoot as many as I can and dispose of them on my daily jogging tour.
As to their habits, I guess that some squirrel families are predisposed to gnaw their way into a house. I had two groups that were troublesome, but once I got the last of them the other groups do not seem to like indoor living.
But, I play it safe with a high powered 5,6 mm air rifle.
No more vermin damage for several years now.
Ola
