SRP tube heater
diy96
Winnipeg, Mb.
Hello,
New to this forum and really enjoy the great info here. I just installed a 45,000 btu SRP tube heater. Minimum clearance to the ceiling is 3" at a 45 degree mount. Installed at 4.5", ceiling is osb. When it runs the ceiling temp at the leading edge runs at 175 degrees F which seems hot to me. The manual states the clearance to combustibles are rated at 90 F higher than room temp, meaning the temp can be 160F based at 70 F room temp. Does this seem right? Should I consider installing a heat shield to lower the ceiling temp?
Thanks for you insight.
Slowgsr
Southern ontario
I have a similar heater, 45k schwank...
Mine had similar specs, even @ 6" the ceiling gets hot (I can still hold my hand on it without discomfort) but everything is 5/8 type x so I'm not concerned.
If I were you I'd build a shield, even just a strip of concrete board with an airgap between the osb, use some metal furring channel. Then you could paint to match the ceiling if your ocd like me.
nickm1024cobra
Chicago Suburbs, IL
I would get some sheet aluminum and extend it a few inches. Pop rivet it to the shield. 175 seems hot....
I have a tube heater mounted at a 45 and ceiling only gets about 130. Im also at about 8" clearance.
D
diy96
Winnipeg, Mb.
Hi there,
Ended up installing a heat shield made out of .060 aluminum. Made a drastic reduction in ceiling heat. Bring on winter!
mx500
i have a detroit radiant, and it came with a shield. ill check the clearance, but I'm sure it was 12"
