Stahlwille 435QR Help!
eleblu05
baltimore md
Hello Guy's
Requesting some help here i bought a stahlwille 435QR 3/8 ratchet. so i disassemble the ratchet to grease and guess what stahlwille pinned the end of the bolt so one of the bolts are striped out . so my question is what size are the bolt used on this ratchet and where can i get them thanks -Craig
T45
"Low maintenance, easy-to-care-for construction
without screws (FOD)."
Looks like this is a different model? :headscrat
T45
OP, do you have pics?
Do you know the removal size hex or torx or whatever? A standard caliper should be able to measure the fastener. That part might not be user servicable. You're other quick options include taking the bolt to an ACE hardware (they have a metric thread tester), or using a standard table for machine screwdimensions.
That being said, you need to check to see if the threads (female) are damaged as well as the fastener. That's probably obvious as well, but if those threads are stripped you may need more than a new set of OEM fasteners.
maico
England
The 435QR service kit contains 1 pinion; 1 pawl; 1 lever with pin; 1 ball; 2 compression springs; 2 screws. You could buy that if you plan to keep the ratchet.
