Stahlwille Wrench Set Decoder?
FloorPaint
Northern Virginia
Stahlwille wrench sets will have numbers like 10/15 or 10a/15. I’ve figured out that the second number is the count of wrenches in the set, and it seems that the first number refers to the design of the wrench (e.g. double box end, double open end, etc.). Is there a decoder for the first number? For example, what’s the difference between series 10 and series 10a?
tamaraw
The trailing "a" in the series name typically denotes fractional inch measurements (vs metric). Not sure what their designation for Whitworth would be if they even still make those.
The number after the slash for a set just tells you how many pieces are in that set but it doesn't tell you anything about the range of sizes. For that, you have to check the item description.
The series numbers (10, 13, 14, 20, etc.) do seem rather arbitrary and you just have to look up what they correspond to.
Dave455
Sussex, England
The easiest thing is to look at the selection available from one of the online retailers. TBS have a fairly full selection available!E5E37717-1F92-494E-B8ED-91F1AE3436C5.jpegC9CC4C22-62FB-4DBD-8922-BCA57348D930.jpegD0DAC5D7-73BE-409C-823F-10A4C48713D5.jpeg17F32BDB-F44C-4CBA-AA2A-ABEB50BD6EF9.jpeg
As you can see from the catalogue extract humber2 supplied, the system is quite logical, as the numbering originally started at “1”, but some styles have now been discontinued.
The only wrenches that are not numbered in sequence are the aerospace spec wrenches. They denote these with an extra “0” in the part number e.g. a No.13a combination wrench becomes a No.130a.
Once you have worked out the system, you can amuse yourself by asking your dealer for tools that don’t exist, but sort of should do!
F
FloorPaint
Northern Virginia
The image files combined with the series number is really helpful! Thanks!!!
