hh76
Like many projects, this one started as a quick one, then the snowball began rolling. I've never been a huge fan of solid color flooring, and I kind of liked the age that my old slab showed through it's stains and cracks. Figured I'd throw it out there as a possible alternative to other popular floor treatments.
Decided to put up a wall to section off a 400sf area of the shop off for heating purposes, and to establish a "clean room" where I didn't have to worry about covering up the shiny projects when welding or grinding. I was just going to power wash prior to putting up the wall, then decided it'd be a good time to take care of some of the uneven spots on the floor, and then why not grind the whole floor, then why not re-seal, and what the hell, while I'm at it I might as well add some color.
1. power washed
2. ground the hell out of it
3. power washed
4. filled cracks and holes
5. ground a little on a couple spots
6. power washed
7. stained- I used a transparent, water based, penetrating stain that I got from a concrete place I deal with for work. I tried a small sample of acid stain, but wouldn't penetrate the ground concrete.
8. lite cleaning
9. sealed with clear epoxy
Pictures have a tough time showing it, but it's blue, with a lot of variation. By no means a perfect floor, but no amount of polish could make that 50+ year old turd of a slab look new.
I'm not even close to a professional, so don't take this as pro advise. All the pros and product reps, don't feel like you have to pull any punches when critiquing my floor. I can take the critisizm, and your advise may help the next guy from making any mistakes I may have made.
1. power washed
3. power washed
6. power washed
8. lite cleaning
