Staining a Post/Frame structure
BirdHunter
West Texas
Hey guys,
Long time lurker, first time poster.
I have tried the search feature but didn't find much on this topic.
On tuesday I am signing the contract on a 30x40 post/frame building with engineered trusses.
In short, the steps are frame, concrete, metal roof/skin.
My question is, are there any pics of, or has anyone stained their structure prior to concrete.
Thanks in advance.
Voi
Western South Dakota
I was researching Barndominiums for a friend of mine recently and I did find examples of stained poles. As I recall you'll have to research more than just that term and sort of "get lost" in the topic. In the process I'm sure you'll find many examples.
kd3pc
Northern Neck
stain works well, but you need to use a premium brand and make sure your wood is consistent ie clean, no oil/dirt stains, reasonably dry and the like. Then the color you choose. I use Sikkens and often their marine stains as they hold up better, especially with "damp" woods like pressure treated.
I "pre stain" with a spray gun as much as possible, but that often only works if your crew will let you have time to lay it all out and time to do so. If you can not prestain...you will have a LOT of labor just getting to the wood, as well as consistent coverage - which equals consistent color.
If you pre stain, you will need to cover, if the contractor doesn't - ANY exposed wood or stained wood up to 6 or 8 ft....there is nothing worse than concrete on a newly stained post unless it is a hand print.
You can also use "oils" and they too hold up well...tough to spray, but easy to roll. I have done timber frames with teak oils, linseed and other heavy oils - with beautiful results. Make sure you keep the brand, color and type of stain so you can touch up things down the road.
