It honestly depends on what you're purging. The settings for 6" sanitary pipe will be different than 2" sched. 40.
Whatever you do, be consistent in your settings. Choose a CFM, hole size, welding current for a given wall thickness, and so on. By doing this you ensure consistent results in welds you can't check. Find what works for you and stick to it. Learn to walk the cup, and tail out without a foot pedal. I assume you're welding pipe of some sort, you didn't specify.
On 16 GA wall sanitary pipe I run an 1/8" hole, 10 CFM and 35 amps, usually walking a #6 cup with a 1/8" tungsten sharpened 1:1 taper, fairly recessed for the appropriate angle.
Here are a couple of shots of a weld I did with the settings described.
