TimDaToolMan
- Joined
- Mar 14, 2013
- Messages
- 536
Why do they make tools out of chrome plated steel, why not just use stainless steel?
So you can afford to buy them. If your shopping in the craftsman price range you wont be buying stainless. Stainless also has very different properties in stiffness, strength and hardnessWhy do they make tools out of chrome plated steel, why not just use stainless steel?
Was my answer overkill.
Stainless is usually softer than standard steels.
This is incorrect.
Yeah, your generalizing statement is completely mistaken. Get yourself some CPM-S60V stainless tool steel and see how soft it is.Stainless is softer than tool steel.
You are incorrect, with regards to tools (and that is the root of the question).
Tools are not generally made from mild steel.
Anyway, hardness is just one attribute of steel that is considered when a tool is made. Toughness, and elasticity are more important.
Also, stainless is more difficult to drill than cr-mo for example, because of work hardening. That's got nothing to do with the metal's innate strength to be used as a tool.
For some cold hard facts, I have a magazine that did some destructive testing on hand tools.
Wera's stainless steel 5mm hex key had a HRC 54.6 and it took 48.468 Nm of torque before the drive end sheared off. The DIN standard for a 5mm hex key is 35 Nm.
Wera's stainless steel PH2 screwdriver had a HRC 54.4 and it took 20.405 Nm of torque before the drive end sheared off. The DIN standard for a PH2 screwdriver is 10.3 Nm.
In my experience, stainless isn't used because of its hardness but rather to resist corrosion. Keep in mind, my experience is mostly with pumps and different types of fluid......like aggressive water. Ive also done a bit of work with food grade seal-less mag drives but still pretty limited.
Just curious, how do these compare to tools made from other materials?
