stainless steel
jim
wi
i have a stainless steel cart (old restaurant) that a magnet will stick to. Then a got a stainless steel tray from work that a magnet will not stick to. I know there are there different grades of stainless, or does it pertain to thickness that make a magnet stick to it or not? Jim
4 FN 27
Minnesnowta
The Magnetic Stainless is 400 Series. The Non-Magnetic is 300 series...simplest answer...
Ferritic Stainless Steels are "generally" magnetic while Austenitic Stainless Steels are not.
exmaxima1
Midwest
Yep, and sometimes a 300-series item (like a sink) will become mildly magnetic after it has been drawn or work hardened.
MoonRise
I don't think it has anything to do with the thickness. Has to do with iron content I would think.
Nope. :lol:
Whether a stainless steel alloy (or other metal or metal alloy) is magnetic or not depends on the internal 'crystal' structure. As well as the mix of the different elements in the alloy.
As mentioned, most austenitic stainless steel alloys (the 200 and 300 series) are (mostly) non-magnetic. But may become slightly magnetic when cold worked.
Most of the ferritic stainless steel alloys are magnetic, as the most of the martensitic stainless steels.
anndel
Hawaii, USA
Love all the discussion on SS. My buddy who died several years ago was a metallurgist/materials engineer and used to tell me about metals for knives, cars, etc.
fatfillup
Finksburg, Md
Nope. :lol:
Ok, I did a little googling and now have just enough info to be dangerous:willy_nil
Here is a link to Martensitic stainless and it contains iron so I am partially right, I think.
https://en.wikipedia.org/wiki/Martensitic_stainless_steel
Here is a link as to why a magnet is only attracted to iron, nickel and cobalt.
https://www.quora.com/Why-does-a-magnet-only-attract-objects-made-of-iron-nickel-and-cobalt
Since Ferritic stainless contains chrome and a magnet will stick to chrome, it sticks. And since ferritic would infer ferrous and to me ferrous relates to iron, I am again partially right:thumbup:
https://en.wikipedia.org/wiki/Ferrous
Now, here is the crux. I am a layman and this explanation is close enough for a guy who will never forge a tool or device. For the professional metallurgist, my explanation is full of assumptions, misstatements and is overly simplified I know. But we all can't be experts in everything. :beer:
rlitman
Long Island
Iron content has little to do with it. I cannot read your quora link, but no, iron nickel and cobalt are NOT the only ferromagnetic materials, and simply putting ferromagnetic materials together does not a magnet make.
Ferritic stainless contains chrome. So does martensitic stainless, and austenitic stainless. Typically (but not in all cases) austenitic stainless contains the most chrome of these three. Yet, while you say that chrome is magnetic, austenitic stainless is the least magnetic of the three. In most cases, it is hardly magnetic at all.
PelicanPines
I have gotten into so many arguments over this topic. A lot of people say stainless can't be magnetic... and I open my big mouth and explain what you fine people explain clearly that always escapes my brain when I need the details.
THANKS !!!
velocipede
Yorktown, Virginia
So...they could have made my refrigerator door out of magnetic stainless, but chose not to to deprive us of the pleasure of seeing the grand kids pictures every time we go for a snack! That's so low.
monkeyspanners
Oxford, UK
Not necessarily true, 400 series stainless steels (and
possibly others) can be heat treated similar to steel alloys. This makes them very very tough and wear resistant.
My experience is only in the dairy industry here, all the milk vessels are non magnetic food grade stainless, the outer skin on the vessels are generally made of the same grade but there are a few cheaper tanks which are magnetic.
BikerDad
Utah
A correction on terminology being tossed about:
ALL steels are mostly iron. By definition. If it is steel, it is at least 50% iron, and will have some carbon, but no more than 2.1%. This is true whether it is a mild steel, stainless steel, low alloy, high alloy, or any of the more exotic steels.
allinon72
Indianapolis
Work with stainless a lot at work - we check to see if it's magnetic and if it is, we generally view it as lower grade stainless. And it tends to rust as well.
Fcvapor05
Stainless comes in different grades. Basically the more steel it has in it will affect how well a magnet sticks to it.
All stainless steels are approximately the same percentage of Fe.
Magnetism is directly related to atomic structure. Austenite is the primary allotrope present in non-magnetic stainless steels. Some of them can be cold worked to become slightly magnetic- this happens because the cold work process can change a low percentage of Austenite into other magnetic allotropes.
