all depends on application and do NOT mix materials, then you are asking for issues in most cases. 90% i use zinc steel, few places where recommended or exposed i use SS.
Automotive i use the Gr 5 or 8 depending on loading
Can you enlighten us on this? I am well familiar with two metal corrosion. I assume that is what you are referring to with using two different materials. It comes down to the difference in the electro negativity differences beween the two metals in contact. It has been a long time since I had to think about this.
I know plating like galvanizing act as a sacrificial anode and the zinc gets eaten before the steel.
I am not sure there is enough of a difference between Carbon steel and stainless steel. I would have to dig up one of my old college books and look it up.
I have used St. St. nuts on steel muffler clamps many times and it has been a help vs. a problem. If I ever needed to undo the clamp I could get the nuts off with out any big deal. If I use the plated Grade 5 there would have been a good chance it would be a struggle to get them off.
I am always open to learn something new.
