deepstuff
Hi,
I'm building a 32 x 44 with 8/12 pitch. I'm limited to 10'-8" walls. I may be able to push them a little higher but not above 11'.
If I need the height, I plan to use 16 feet of scissor truss in the back end and rest attic trusses.
If I use scissor trusses I'm struggling with how to and where to put stairs to loft so as not to disrupt too much floor space. I have seen the examples here with the stairs half way along a long wall. After living with them is there anything that you would do different?
I have even thought of putting attic in back of garage so I could put stairs on back wall but that has other draw backs.
I have also thought of a cat walk from back wall to the attic space but that interfere with the additional height.
Again, anyone out there living with them and would do something different or the same again? I want permanent stairs as attic may become a man cave?
