ddurrett896
Looking for a stair calculator to access the attic in my garage. Would like something where I can plug in my rise and run and it spits out the # of treads and what they need to be cut at. Thanks!
god calculator here. plug in your measurements . lots of info available if you play around with it .
https://www.blocklayer.com/stairs/stairseng.aspx
It doesn't need to be built to code if your not accessing living space greater than 200 sq.ft.
That is any calculator. Start with a 7” rise and a 11” run and dial it in from there.
I built my basement stairs with 8" rise and 8" run (2x10 tread with 1 1/2 overhang). I had limited space in an old house but they are comfortable for almost daily use. I would not use less than a 2x10 for the treads.
The old stairs I replaced had less rise but only 7" treads. Those were dangerous for regular use. Especially since the front edge of the treads had been worn smooth.
Whoops, guess the stairs are already built. I did not use a kicker at the bottom of mine. If the top is solidly attached I can't see a big need.
By kicker you mean a 2x fastened to the floor between the stringers to hold them from moving? If they are against a wall that’s not needed if you fastened the outside stringer to the wall. If they are in the open I would add just one in the middle with some tapcons. I am about to build my stairs next week.
