Stair width and height requirements
John Timmins
Flagler Beach, FL
I'm having a home built. The garage slab is one level and there are 2 steps to enter the house slab on a higher level.
My stairs are 7 1/2 high but they seem like they are not deep enough. Once you're in the house, going from the back door to the yard is 3 steps.
Their " tred" also seems to be too shallow. I'll see if I can get pictures tomorrow.
When the slab was poured some 2x10 were built to have the stairs poured at the same time. There's something really half-*** about the poured steps in the garage and also the front door stairs and back yard stairs.
Thanks in advance, John
spudley
Northeast Wisconsin
The rule of thumb is total rise and run should be between 17-18". So if your rise is 7 1/2" the run (tread) should be 9 1/2" to 10 1/2". My preference would be 10 1/2", just feels better.
Rise/run should be the same on all stairs.
J
John Timmins
Flagler Beach, FL
Thank you very much.
In my house I installed maple stair treads I ordered from an online supplier; they are 11 inches and very comfortable.
J
John Timmins
Flagler Beach, FL
Spudley, I asked my building inspector . He's not a young man. At 72 he has been doing this a long time. He said some of the rules are so spread out in the rule books that sometimes you had to take notes from 5-6 different rule books to to get an answer for something.
I have asked a question about stairs that could get more complicated than your 17-18 inch rule. He said that was a rule that used to be true. While it makes sense, that rule of thumb, Different localities can make a mess of it.
He said it varies ! However, I like what you wrote. That 10 1/2" just feels better.
What if my cement stairs have standing puddles in low spots ?
wrenchguy
NW Indiana
there is a difference between the finished stair tread dimension and the framed carriage dimension that carries the tread. carriage dimension x number of carriages = stair run, not including the bottom tread overhang... usually 1 1/4". i make my concrete steps about 12" x rise.
PelicanPines
We had to pull the steps in a friends garage... 3 steps... not ONE the same as another. They used scraps and it showed it.
No matter what you do do… the measurements and suggestions by Spudley should be a builders left arm TATTOO... split the number of steps height so they are ALL the same amount of step... all the same depth... using those proportions.
Gerald O
NC
Code usually allows the last (or first) riser at the bottom of a stair run where it meets the lower floor to be of a lower height than the other steps. But you still want it as close as possible.
