From Generac Q&A site about the 20kw....
Our home standby generators up to 45kw come set from the factory for natural gas but are easily field convertible to propane. To convert from natural gas to propane, and vice versa, you will want to reference the section in the owner’s manual titled “Reconfiguring the Fuel System.” This section of the manual will detail the steps to convert from natural gas to propane, and back, for each of our different models. It is not advised to continually perform this reconfiguration, but in the event of an emergency or a change in available fuel supply, it is a simple conversion. Local codes will dictate what is needed to adequately and safely supply the fuel required. Unfortunately we are unable to determine the proper way to install this type of set up for your particular application as we do not specialize in gas line installation. You will want to work with your local certified plumber to determine the best way to install the unit to meet your needs. It will consume approximately 2.9 gallons of propane per hour when operating at full load. The fuel consumption will decrease as the load decreases; the unit will consume approximately 1.89 gallons of propane per hour when operating at half load.
