pendragon1998
I wanted to share this tool failure in case anyone else has one of these hacksaws. I have actually really enjoyed this saw and was expecting it to last a long time. It's a pleasure to use. Unfortunately, the tightening lever pivots on two pins that are cast (diecast) integral to two ears of metal, and they both failed on me. I left the saw hanging with the blade tensioned very tight (as I typically have done) and apparently, the metal was fatigued enough to break both pins off. When I took it down, both pins just dropped out. If you have one of these saws, you might want to be aware of this.
I'm not certain there's a way to avoid this problem, as keeping the saw loose when you aren't using it doesn't seem like it would help. You'd just fatigue the pins when you tightened it for use. I don't believe this saw has any parts available, but I haven't checked. It's a discontinued, made in the USA model.
I will say again that I've been very happy with the saw until today. I'm really bummed my saw broke. I may still look out for another one of this model. Anyway, thought some of you might be interested.
I thought I was only one with that luck... Must be an Alabama thing.
