I've done a fair amount of radiant jobs but they have been almost all either poured into a basement/garage slab or a staple down with lightweight concrete poured over it.
Friend of mine has a 25x35 shop built within his 50x100 steel building, the shop has 16" I joists supporting a second level that will be a man cave in the future.
The entire building is prepped for radiant with the lower shop area a separate zone, we would like to do a staple up between the I joists for a 25x25 section of the second level that will become the man cave.
Can this be done without the use of any reflective plates? Most staple up jobs that I've seen used some sort of aluminum plate to direct the heat up, are these necessary if the entire joist space is filled with insulation?
Any thoughts?
Any thoughts?
